Rear Brake help!
mudluva
New to me 2010 with only 8 hrs on it. When I push rear brake it requires a much harder than normal push to get braking and very hard to lock it up? Tried cleaning the disc, and bike is like new but this brake issue concerns me? Front you just touch and it is super.
Thoughts?
just went thru the bleeding process of opening bleed screw, push brake, close screw, let up brake. did this approx 20 times.
brakes still feel like you must apply more than normal pressure to get rear brake stopping?
has me stumped?
Caliper seems to slide free on pins, fluid level good, pedal adjusted, but still need more than normal push to activate brake ?
would my 20 or so pumps of brake, bleeding fluid, be enough?
a real mystery....
I'm not sure what your brake line is made of, because I have seen SS, plastic and rubber on different models/years Huskys.
If the hose has been crushed it can be restricted on the inside and look good on the outside. I have seen it before and the symptoms match your's.
a real mystery....
