Kanon Palmgren
Since I bought this 08 TE 450 I'm about to have THREE new fuel pumps in it! I bought it hardly used last October at 139 miles. I immediately put a new pump and steel automotive filter in it. It didn't run so it went to Uptite for an assessment. He cleaned the injector, and replaced my CA Cycleworks pump with something else new. He also added the PU kit with his own pipe and tune (told me he spent countless hours trying to reflash the stubborn comp); picked it up in February. I got two great rides on it, one good and then a miserable Sheet Iron 300. Midway through the ride I started losing power between 5k and 6k (oh and it'd die between idle and 2,100). At the end of the day that dead zone had increased to between 4,500 and 6,500 with an 8k limiter, ??? I'm pretty sure it used to be like 11 or something. Day two I could hardly get the thing started with 200 miles ahead of me. The condition didn't worsen until maybe 60 miles in when the bike just started choking out and died, then gave me the flashing neutral light. My buddy towed me down the hill to Ukiah where I was able to thankfully get a ride. Fast forward back down in LA I notice a blown fuse, replaced it and the bike started but resumed the original shitty performance (dead bike between idle and 2k, no power between 4.5 and 6.5 with an 8k limiter). Then I hit the forums looking for similarities, battery is totally charged and good, the wiring harness is nearly new, all new fuses and Uptite's great safety wire job has kept the pump more than in it's place. I then took it back down to the shop and he told me it's running lean and isn't getting proper fueling, bad fuel pump. How can one $100 pump not work sufficiently and now another has failed within a mear 361 miles? The current pump does prime but the bike doesn't like to start before 6+ priming cycles..... This thing is driving me nuts. Am I gonna have to drop $100 into this P.O.S. after every two or three rides or do I have a faulty computer or something?????? Oh and I stabilize the fuel I put in the thing and I personally have never messed with any ecu, tps, or idle speed settings.
Any feedback would be appreciated and if this thing ever gets up and running there's an 80% chance it'll wind up in the classified section. Here's a pic of what to look forward to:
Thanks
Thanks
