  • 2 Stroke Husqvarna Motorcycles Made In Austria - About 2014 & Newer
TE/TC Raise idle
Xicobombas
Need to raise the idle on my 2017 TE 250.
Even when hot in tight trails with full clutch it stalls.
Brought it from dealer maintenance, a bit far to take it back, and need to raise the idle.
Come from a 4st, only 1 screw to control idle, after reading the manual got scared on f.. up the dealer settings.
Any video ?
Do I need to raise on both screws (air and fuel) or just one screw (air) ?
After reading better the maintenance manual, I think I understood how to do it.
Need to use the speed idle screw and set the speed to 1400 - 1500 rpm.
Then with the air idle screw, check the highest and lowest working point and set it to the middle point.
The problem is, how can I see the idle speed ? My previous 4st TE 250 Husqvarna had the info on the dashboard, the present one doesn't.
Before raising the idle too much you might want to play with the low end jetting. On a good running 2 stroke the idle doesn't have to be as high as a 4 stroke. Cam.
Hello, recently got a 2 stroke time for a change.
My te 250 idles fine but it seems to take some time to come back to idle so idles fast then comes to rest, noticeably different to my mates 17 te 300
Any ideas? The cable and side are not sticking.
