quick battery question 09 txc
Wolf
09 txc 250.estart died during a ride yesterday. Starts instantly with the kick start, as usual, but nothing happens when pushing the button. Dead battery? Wouldn't surprise me, its old :)
Can't tell without a voltmeter hooked up to it, should read 12.8v standing and 14 or so when running. When cranking, shouldn't dip down below about 10-11v for long before the bike fires up.
Check the switch in the clutch. It's hidden up underneath and activated when pulling the clutch in to allow the bike to start. Follow the wire up to locate it.
It could just be loose in the housing, if so, tighten her up and try again. If it is broken, you can bypass or replace it.
This happened to my TXC and also a friends. It can happen to any bike with a Magura hydraulic clutch of the same era.
