I'm running the 32.5 pilot in our TMX-equipped '09's (CR 125 and WR 300). It's one size down from the stock 35 and it cleaned up the off-idle gurgle perfectly in both bikes.Motosportz;37820 said:I'm running the TMX but it does best with a 32.5 Pilot. 09 WR125 500-3000 feet.
krieg;37828 said:We're running the 32.5 pilot on our TMX-equipped '09 CR 125. It's one size down from the stock 35 and it cleaned up the off-idle gurgle perfectly.
I'd try the pilot jet before messing with the float. You may get the change you're looking for with just the jet. Changing several things simultaneously can leave you trying to figure out what helped and what didn't.Idacurt;37831 said:Keihin manual says 16mm float height for the pwk, mine is 15mm.Is this enough to cause issues? I will change it to 16mm anyway.
I may go 1 down leaner on pj?
Me too. Initially, I went to a 30. But after a weekend's worth of racing, some idle instability, and some plug reading, it was clear to me that the 30 was too lean.Motosportz;37830 said:i was surprised how going form a 35 to a 32.5 made such a noticeable difference.![]()
NWRider;37842 said:I just go both ways and see what happens sometimes.
