Hello. Need advice.
Sorry for my english
The problem:Motorcycle - Husqvarna SMR510 2008. Injector Mikuni. Stock muffler. Mileage 4,500 kilometers. Set Power Commander III. Candle new.
If sharply several times to turn the throttle, the bike will stall with a soft bang. This happens when the bike is stationary or at low speeds (under certain provisions of the throttle). Not always. About one out of five times. If standing on the spot several times greatly loosen the throttle, the bike always stops. At high speed, it does not.Highly frustrating if it happens somewhere in the track with mud up to their knees or at a traffic light when the rear car (((
Power Commander III is set to stand. Characteristics of the fuel mixture - normal.Fuel pump to the fuel filter changed. No changes are seen.Oxygen o2 sensor replaced Oxygen o2 sensor eliminator.
Can anyone advise where to look now though?The reason?Oxygen o2 sensor ruleThe composition of the fuel mixture ruleFuel pump rule
How to get rid of this problem?
What's left?Injector?Problems with the ignition?Where to look, what to test, how to test?
p.s. In any case, repeat the problem:Motorcycle starting up standing still in neutral, the engine runs smoothly, RPM does not jump, all right.Sharply several times twist the throttle - the bike again in the fifth with a soft bang stalls. It stalls at the opening of the throttle, and not at the closing.
