Please help, Need a kick start case.
bondy987
Hi there im new to all this, just finished restoring a 1983 husqvarna cr500 taken it out on the trak once and broke the casing. Hoping someone knows where i can get one, or if anyone has one laying about.
Thanks Sean.
This is a common problem. I assume that it broke at the Kickstart when You were Starting it. The Holes are Machined threw the Magnisium and are not lined and as they wear the Kickstarter gets loose. The later Bikes had the Holes lined with a Bushing and an extra Bolt to the Main Cases next to the Kickstart Hole. I have seen good ones sell for $30-$150 on e-bay and they are some times for sale here as well. A reproduction Case is also avalable it got a bad rap as there were some fitting issues at the begining. I have one and havn't had the issues of others. Its a good replacement for a Bike to be ridden but not a true one for a restoration. Its modeled after a later Cover and is Aluminum not Magnisium and much Heavier duty. DC Plastics can supply them. If You jump over the the For Sale forum in Vintage You might find an oringinal one and or a lead on one. They are generaly refered to a Clutch Covers.
Thankyou very much 1982 xc 430, great help may try for both i think, as i do want to ride it a little. Thanks again
