play in gear selector ?
rabskyline
I rode my 2010 with about 700 miles on it back to back with my mates 2010 450 exc ktm and noticed his selector was way more solid feeling and good and tight with very little movement needed to select the gears compared to my husky which has more throw to get the gears. how do you find yours for play ? quite a bit of movement till gear selected or very little ?
How much does yours move?
Is your gear lever loose on the shaft? There shouldn't be any play between the lever and shaft. When everything is good and tight, it should only move about a 1/2" or so at the end of the lever.
It's common for the lever to get loose. If it is loose, it will need to be tightened before it strips.
nah, all good on shaft. just the throw before it takes a gear is much firther than a KTM of same year with much more miles. just need to tip the Kato slightly and it changes gear where the husky is further . nothing more than curious to be honest ! bike goes 100% so just a question to other owners to see if they've noticed a difference !
My 08 TXC250 has got a big throw going into the next gear ... toe flicks usually do no make it into the next gear ....
