PIston question
antirich
I just realized that I broke the corner of my piston skirt. I think i had something in there to keep the engine from rotating during disassembly, and the lower edge broke off on one size, about an 1/8". I'm assuming this will make the piston unbalanced, so i should replace it.
When replacing pistons on the Husky motors, is it best to re-hone the cylinder? Anything special that's needed?
I know these cylinders are plated, so i don't want to damage it.
Was thinking about a 530 piston, but can't find any for sale without the whole cylinder package. Try to keep costs down.
Definitely need a new piston, if the plating is off the cylinder it will need to be replaced or restored. If the plating is good, you should be OK with a stock replacement or aftermarket part. Wouldn't a 530 piston require a larger bore? If so, you'll wipe out the plating. Try to figure out why the skirt broke.
The skirt broke because i had a piece of wood securing the piston while trying to remove the clutch basket bolt. Totally my fault. Kills me cause the piston was obviously replaced, and in great shape
Cylinder wall looks perfect. Wasn't sure if honing is required with a new piston to help the rings seal on Husky motors.
