Oily Creep
BiG DoM
I have resealed the tappet covers really well, all torqued down etc and my 610 while a bit better is still PISSING oil out the top!! ... enough to spray droplets on my RHS pants leg on long trip! WTF? I recall some talk of the oil finding it's way up the bolt threads etc?? Where is it coming from?
What is the definative fix? - I also hate the look of an engine seeping oil and friends all point and ask!
are you sure it's coming from the covers? i had this problem a while back but doubled up the gaskets and it solved it. oh hang on, i also put a smear of instant gasket over the join of the head and the cylinder block. could try that. i guess you need to find exactly where it's coming from. apparently talcum powder is good for that...
I also put gasket maker with when i do the covers -- one needs to also look at the oil breather pipe that goes into thye frame --here in SA they tend to perish fast ?
It's the threads. I just did my valves and it was leaking pretty bad before, but after putting a smear on the threads it stopped 100%
