oil strainers 449/511
eaton86
Hey guys just purchased a 2012 449. I'm midway through an oil change and I noticed the two mesh strainers are different and I can't remember which way they go?
ust wanted to say I am so glad this forum is here with all of the input that I have gleaned from everyone I have transformed my bike into the reliable single rut monster that I feel confident with, but before I did any mods I spent a day trapped in the woods :banghead: rode about 5 miles worked myself to death thought I was going to have to walk out, but now:
13 tooth front sprocket, FMF power core silencer, the AKRO map installed and race switch plug jumped out.:banana: YAHOOO**************************************** this is want I wanted no more stalling almost climbs hills at idle if I wanted to and still has a top speed of 80mph which is plenty fast enough for me and I did all of these mods for under 350.00 total:D
My 511 will pull past 90 with stock gearing. I have a new 13 tooth, and some new tires to install (Pirelli 21).
Plan on trying the 13 tooth for single track rides.
i Installed the 13 tooth and 49 rear.. helps heaps and use the clutch a bit. Still enough topspeed but also good in single and climps. MAP 3 (Akrapovic setting) here in Australia. Bike comes Standard with two mufflers. Stock taken off, oxy sensor pulled out and AKRO(MAP3) . Suspension Set up done on front and rear. Happy with it. 3 months old and 1000km bush on it.
When you removed the o2 sensor did you have a dummy plug or what
