Oil question, not debate
somdale
Hello guys-n-gals hope all is well with all.
My brother recently retired from riding and gave a bunch of Maxina Maxum4 synblend 10w40.
What's the opinion of that weight in my 2006 TE-250?
dale
If it was given to me, I'd run it, in the winter. I can't run a 40 weight in 98 degree weather.
Maxima’s Maxum4 Synthetic Blend is a blend of ester-based synthetic and petroleum base stocks featuring advanced technology. This special high temperature formula protects critical engine components, reduces wear, friction, temperature, oil consumption and extends drain intervals. The use of new anti-shear additives assures viscosity stability for motorcycle 4-cycle engines with integrated transmissions. The Maxum 4 Blend formula also has extra anti-scuff additives to handle extreme loads and peak temperatures.
Features:
-Ester Based Synthetic
-Viscosity Stable
-All weather formula
-Reduces engine wear
-Smoother transmission shifting
-Extends drain intervals
-Reduces friction & engine temperatures
-Anti-wear & Anti-scuff additives
-Easy starts
-Improves fuel economy
-Formulated for “Wet” clutches
-Maxum 4 Blend exceeds API SG/CC Specs
-Maxum 4 Blend exceeds JASO-MA M/C 4T Specs
