Oil plug thread pitch.
wulf22
Hello. I have a 2009 TXC 250 that has some slightly buggered up threads in the case for the main oil plug. Does anyone know what size tap I have to use to clean up threads in the case? Thanks.
Oil filler plug is M18 x 1.0 thread. Lube up your tap with lots of grease or Vaseline to catch any chips from falling into the cases.
If you can, it also helps to run a liter of cheap oil through ir. Plug in, fill, then plug out, to wash any final bits. I have helicoiled sparkplug threads using only grease to catch the chips (emergency of course) and made out fine. The grease does a great job. Cam.
