oil leak
nep2012
wires coming out of engine on shift side have oil seepage where they go into engine. Not much oil. I was thinking about putting some silicon to seal area. Anybody familiar with this problem?
next time you pull the gen cover, or maybe after using some good solvent on the outside. if you use a liberal amount of 3 bond 1211 (white) silicone sealant your weaping oil thing will be solved. I say 3 bond because because the stuff is top shelf(also $$) and amazing for sealing stuff up.
