Oil leak
109HUSKY
A few weeks ago i did an oil and oil filter change on my TC 250. The other day i noticed it was quite low on oil from looking at the gauge. I then looked underneath the bike and there seemed to be a small build up of oil on the bash plate that was possibly coming from the centre of the engine casing underneath. Does this mean i will need a new seal? Any suggestions on what i should do?
Thanks
Have you tried tightening the case bolts, the ones that squeeze that middle gasket. Mine were a little loose when I checked them.
Oil tends to migrate to the lowest point. I would check your 3 oil exit points being 2 on the bottom left casing and one on the sump. These can weep. Be careful not to overtighten
As ghte said, most likely culprit is the gear selector shaft seal or the seal behind the front sprocket, next is sump plug washer damaged/missing, oil filter housing o-ring, if none of those then case gaskets.
