Oil filters
Bud70
Is there much difference between using a part no 8000a7019 filter and a HF116 filter.thanks bud
HF will do fine, it actually has the oem number on the side of the box make sure it is the correct oem number and its all go.
The OEM cost ten times as much but it comes with seals. You don't need the seals on every change and you can get them separately.
Hi McKay, I have not found that to be the case with thr HF filters. All necessary bits are included.
http://pcracingusa.3dcartstores.com/Honda-Husqvarna-Off-Road-PC116-Drop-in-Flo-Oil_p_42.html
100_7725-jpg.16406
100_7727-jpg.16407
Are they the same overall length? The hf116 looks like the body's longer and the seals thinner? If there the same overall length then they "should" be ok right?? I have only ever used the hf116's :) :)
The only difference is you dont get the new 'o' rings with the hf ones i get from torpedo7, but 5 filters for $20 i'm not really concerned if i have to buy a HUSKY filter once in a while.
Gav
Hmm, Ive been ripped off :D
I bought a 6 pack of them and none had seals. Doesn't matter really, they are still a bunch cheaper!
You want the HF611 I believe, the HF116 is for another application.
HF116 is for x-lite motors . HF611 is for the TE449/511 I believe.
There is a thread on here where someone cut Original and aftermarket filters open, measured them etc... there were slight differences but seems most people use HF116 with no problems.
I think you are talking about different bikes when you mention o rings. With a x-lite the HF116 and Husky filter dont come with the "cover" o ring .
Thats a seperate part number .
Anybody have good luck with the SS filters, like PC-116 above or the Moose version which is probably the same? Figured it'll only take about 6 or 7 oil changes b4 the cost equals out....
Should be able to get the SS filter for $20-30. I run three SS filters in my 511. They flow 7 times more oil than the paper ones, they work great.
