oil filter application question
towpro
My new to me 2008 TE 250 came with some spare oil filters.
Hiflo hf 154. I assume the last owner used at least one. I put one in and rode it around 1/2 mile in the yard.
Now I see it really takes a hf 563. Search showed me at least one other person using the 154 in his 08.
Research (K&N site) shows the 154 is 1mm longer, both have a relief valve but no indication on the PSI.
Anybody know if this causes damage?
I hope this is my last stupid question.
It's a bit of a confusing story with the filters. When we first got the 08's, the 154's were the only thing available to mortals. In 2009-10 the 563's started being mentioned in forum posts and finally made available. I only used 154's in my 510 from 08-10 with no negative results after 2000 miles, including valve clearances. I did not ride the bike hard. This is my personal experience with the filters.
My 09TE450 came with a 563 in it but the 563 was not available yet in the US till about 6 months into owning the bike so I ran the 154 for awhile- yes we all ran the 154 at some point (not 1 or 2 people).
Basically, the only difference is the oil bypass valve uses a different pressure. The 563 is better matched to the circuit the bypass spring is stronger. So the 563 bypass will hold back more oil pressure than the 154. If the 154 is longer- the 563s seal probably makes up that difference. The seals are also different. In the end- the differences are small enough that you should not worry about running a 154 if you have some spares. But when you purchase new ones- get the 563. The 2 times that the bypass valves is supposed to come in to play are when the oil is cold and you rev the motor and the oil cannot flow through the filter fast enough it goes through the bypass rather than destroy the filter... the other time would be if the filter were dirty enough to be clogged and restricts flow. Goes back to emphasizing NOT revving a cold bike... and regular maintenance.
So Run the 154 and seek the 153 upon your next purchase.
