Oil Change on TE-510
Stomper51
I just did my first Oil change on my TE-510 and change the filter and clean the 3 screen in the lower case. when I removed the single plug that holds the single screen there was more oil that drain out of the case, is this normal. then when I was adding the new oil back in to the case I put in around 1.2 to 1.4 quarts of oil and It was half way in the glass and the book said 1.8 quarts of oil is there something I am missing. Do I need to running the engine or ride the bike a few minutes and then recheck the oil level.
Oil draining when you remove the screens is perfectly normal, also to check the oil level the bike sound be running, on a level surface and upright. It bet once you fire the bike up the oil level in the window will drop dramatically.
yes run the engine...then check with bike level
you can actually drain all the oil from the lower screen cover on the left side.....and not touch the drain bolt (but its always good to pull it anyway to check the magnet)
I actually do it this way....tip bike on right side(lay it on its side) remove left side screen cover and screens and clean them(dont put them in yet)...then flip the bike over and lay it on the left side (catch the oil is coming out of the lower screen hole)..while the bike is laying on the LH side I now replace the RH filter and remove the drain bolt at the same time to check the magnet...
then flip it over again to put the screens back in... and then fill the sump....
might seem complex...but it saves oils running all over the place
Yes, you certainly can get a few more ounces of oil to drain by leaning the bike over with the two screens out.
On the bottom drain plug, (crank pin plug to I imagine) make sure you put the washers smooth side toward the motor. Mine was an oily mess under the motor untill I figured this out.
