Oil change at 600 miles - found debri in left side mesh filter
nex
I cleaned it out, 2nd oil change (did 1st oil change at 300 miles, just replaced the filter).
There were non-metal particles, some as large as 2-3mm long in the mesh filter on the left side of the bike. Right side mesh filter and oil filter looked fine. Nothing came through in the oil or on magnetic plug.
Ideas where it could have come from and what it is?
It does not make any sense to clean right side, because it is always clean... You just change oil, filter and right side.
I think you mean left side.
Nex, was the debris you found stringy rubber/plastic? That is just excess case sealant from when the motor was assembled. I just did my 3rd oil change at about 2800 miles and I still had a few strings of the stuff in the mesh tube.
You're going to get some crap like that stuck in the left side screen for the first couple oil changes. It will slow down over time. I still get some little bits in mine at 9100 miles on the odometer, but nothing alarming.
I would also get chunks of RTV sealant in the left side screen after a valve check, when I was using RTV on the valve cover gasket. I have since stopped using sealant on the valve cover gasket. It doesn't leak without sealant and I'd rather not deal with the mess.
To this day, I have yet to find anything in the right side screen. If you want to check the right side religiously, do it every time you check the valves.
I'd guess if you started finding chunks in the right side screen, you have something wrong.
Yes, left one.. my mistake :)
