oil capacity in TC510
Paul S
I did a complete oil and filter change on my 2008 TC 510, the manual calls for approx. 1700ml when doing so. I can only get 1300ml into the bike when it reaches the level between the 2 marks in the indicator window. I once added more, but it started to eject it from a vent hose while riding. Should I go by the the indicator window or the manual? Thanks.
Go with the window, read it when it's hot AND cold and get familiar with what it reads both times.
Did you change the oil with the bike on the kickstand and did you pull out both screens?
I didn't pull the screens on this oil change, just the filter. I changed the oil with the removable triangle stand in; I lean the bike at different angles until no more oil drains.
That may be the difference, the forward screen area seems to not completely connect to the sump where the drain bolt/rear screen is located. Had you removed the front screen, you would have drained the remainder of the oil. I found that if I don't want to pull the screens, if I just loosened the forward screen hatch and let the oil dribble out, then I got my full oil change.
Thanks, I'll keep that in mind during the next change.
