Oberon clutch slave cylinder on a 449/511
djdougiedoug
Does anyone know if one of these will fit a 449/511?
http://www.oberon-performance.com/acatalog/Husqvarna.html
I can see on ebay someone selling a standard slave advising it fits most Huskys therefore this might fit.
It's got to be an improvement on standard......
Interested but do not think so. The 449/511 is totally different clutch design being crank mounted I assume the play is totally different.
Clutch drags when cold,
Poor feel and modulation in the lever,
Probably not available from KTM yet so aftermarket is best bet.
Usually OEM slaves are designed to be bare minimum, with one sealing ring and possibly flex/distort. Aftermarket is much more expensive but better built (in my past exp mostly on my husky sm450r).
Check the original part numbers for say a TE250, TE450 & the TE449/511 on the Husky on-line catalogs.
If the original numbers are the same, the aftermarket will be.
