O2 sencor
newtohusky
I have a 2012 TE 310 that is in power mode What would happen if I put the O2 sencor back on the bike , with out changing any other settings ?
The sensor is a narrow band sensor. It adjusts AF ratio to somewhere around 14.7 say. Powered up, the bike uses a map that gives you closer to a race mix...13.2 or so as well as the advance curve to take advantage of that.
So you'd run leaner, more mpg
