icebergstu
Hey peoples...
I have a 2006 TE610e - Flat slide carb model.
Got bike back from Mechanic after new rings.
Riding along and pulled into a dirt road at low RPM
Accidentally flicked the kill switch which made the bike cut out then immediately flicked it back on again which is when the trouble started.
Bike ran as if on idle jet only. Anything over the tiniest bit of throttle and it would try and stall. Seriously only able to do 5kph.
That didnt last long. Stopped. Couldnt re start. Got picked up and trailered home. (embarrassing)
Got home immediately thinking blocked jets and got to work pulling carb apart but all was perfect.
Checked for spark...NOTHING
______
I dont have a multi meter and wouldnt have a clue how to use one.
I have a simple test lamp you connect to an earth that I use.
I have pulled apart the starter assembly switch which is brand new and looks good (10klm old)
Bike turns over beautifully.
I can stick a screw driver in the plug lead, turn it over and hold the metal part without the slightest shock. There is no electricity getting to that plug lead at all.
Coil is 10klm old.
The loom is 10klm old.
Key barrel is 10klm old.
Every electrical thing except the stator is 10klm old except the battery which I bought and installed today. Mechanic inspected and tested stator and found it to be in excellent condition last week.
The bike ran perfectly, started within milliseconds of touching the starter button. It was perfect...for 10klm.
______
I need to figure this out before my head explodes...any ideas???
Stu
______
Coil is 10klm old.
______
Stu
