Jayden-R
I have a 2010 TXC250 and i'm about ready to just take it to a shop, that's how frustrating it is.
It was running when I bought it but the stator was bad so it wouldn't charge the battery. That was back 9 months ago and it hasn't run since.
the parts I've replaced for ignition are as follows: USED stator, new coil, new plug wire and boot, new spark plug.
I Have no idea what is wrong with the bike, I have checked my grounds and connectors to make sure they're good, but I really don't know what else it could be at this point.
I'm wondering if maybe it could be a problem with the flywheel? I haven't looked at that yet but it was working before I took it all apart.
Any help would be greatly appreciated.
EDIT: I took apart the terminals for every fuse and cleaned everything like i was on cocaine. What could it be at this point? I'm confused because it ran when i took it apart. My next move is to take apart every connector I find that related to ignition and clean the hell out of them.
Here's to hoping I'll be able to put a second hour the bike after 9 months.
EDIT #2 Problem fixed. wire was grounding out to another wire in the wiring harness. ECU reset and it's sparking, now to fix the terrible bottom end bog it has.
