Peter Nilsson
Hi all,
I just reassembled my TE-250 2010 after top end overhaul. New piston, cleaned up the top, valve adjustment. After reassembly when I try to fire her up, nothing... There is a spark, there is gas. Ignition is set at TDC with aligned timing marks n the cams. BUT, I cant help thinking that I might have the timing one stroke off!! How can I tell if the piston is one turn off? I cant find anything in the shop manual for this, any marking on the ignition somehow? I mean, the spark may not come in the compression stroke if you see what I mean.
If not this, what else should I be looking for? Maybe it is common to have a really hard starting engine after piston change? I emptied the battery (quite quickly) and spent some minutes on the kick...
Thanks for all help/input.
Peter
Peter
