new sm 610 owner
parlapipas25
hello to all of you, buy a sm 610 with 6000 kilometers 06 model.the bike bought 2011 from stok and have yet warranty.everything is fine but I have a problem .. when the bike is stopped I can not put netrual.my sevice guy told me that all husqvarnas doing that.change oils put semi-synthetic and again the same..any help?thank you
Try selecting Neutral when you are still moving slightly and coming to a stop. I find it the easiest way to get the bike in neutral.
Otherwise a Oil change will help however you say you have already done that.
Could be that the clutch cable needs adjusting.
This is what my service guy told me but I want to ask you guys if this is normal?
My cable adjusted by my service guy.
Yes, this is normal. You need to catch neutral as you coast to a stop or you might need to blip the throttle. You might be tempted to adjust some of the slack out of the level to reduce the clutch drag -- you probably should not do that as it can put stress on the ball and shaft that actuate the clutch.
If the slack rapidly increases across a few days, you might have an issue with your cable or your actuator arm -- see this link:
http://www.cafehusky.com/threads/sudden-slack-in-clutch-lever.19101/
My SM610 didn't drag the clutch until I put a short-pull Arc lever on it. Back with the stock lever and no clutch drag.
I say no, it's not "normal" for the clutch to drag and no, not "all 610's do it."
