New 2013 Husky txc310r
Jacob Sedlock
Hey guys just snagged a great deal on a new bike and was reaching out to the people who already have the '13s what have you done and what all should i plan on doing to the bike to get her RIGHT?
TXC should be right out of the crate. TE's take a little massaging to get them right.
TXCs run pretty strong. We've been winning races with everything stock except suspension set up for rider.
Added TM Designworks skid plate...didn't make it any faster. Its durable, but the mounting setup is a bit of a kit.
Just started running an FMF pipe. BMP downloaded 'open pipe' map. Now its louder, faster and throttle is almost too responsive.
Like Mike says, you really dont need to do anything but tighten and lube everything and change oil religiously.
Thanks for the input guys I'm looking forward to breaking it in this weekend. Thought about taking baffle out and air filter screen as well.
The OEM Leo Vince dB insert out will most likely require/be best to run the open map.
The machine runs very well in OEM insert installed set up (FYI) and may be a little less hyper in this mode.
PS my sponsor shop is getting with LV USA to find out if their catalog listed dB-S/A insert is a standard size item that can fit the OEM Husky pipe as well.
I need to have an S/A as well as a good dB level for AMA Enduro/XC races out here, and want to eventually get the FMF full system when I can, but need to be compliant now. (all this is for CH info)
Hey Robert, I got the s/a from the TE(8000H6855), fits right in the stock can on my '12 TXC. It got a little louder but still passes our sound checks here. Oh and it only lists for $28.75.......... Not sure if '13s are the same......
