My bike has the same mods as yours. The JD is what ties it all together. Without the JD the bike was not much fun to ride - too lean and not smooth. With the JD it is a blast. Cam
Do you have a 610 or 630? 1lunger has his 610 dialed in quite well and has shared his settings. I posted my 630's JD tuner settings on a different thread some time ago. Remember, each bike runs a little different so tuning takes some trial and error. Starting with JD's initial settings and adding fuel in each range until there is no longer gains will give you the best results IMO.And twice on Sunday! But seriously.... settings?
I've got a 630. I'm happy with the out of the box performance I just need more fuel range. I'll seek out your settings and compare. Thanks.
You won't get better mileage than the obnoxiously lean settings of the stock, non-PU'd bike.
100 miles per tank... I weigh 250, ride aggressively and usually in the mountains.
Can someone educate me a little bit on the JD Tuners? I'm interested in getting one, but I'm curious how JD offers a single part number for the TE450/510/610-630 (08-12) that will work for all these applications. Maybe I'm not understanding how the thing works yet, but I would think its default settings would be different depending on the bike. All these bikes don't run the same ECU and maps I wouldn't think, so how could one part work for all of them?
FYI my bike has a Leo x3 system with the resistor plug in/O2 sensor removed. I'm in the rich map and now getting about 40mpg (down from 55 stock). I was told the O2 sensor has to be removed and the bike on the "race map" for the tuner.
All the JD does is plug in between the ECU and the injector, it doesn't interface directly with the ECU.
The stock settings of 3 across the board doesn't really do anything. By increasing or decreasing that number, you increase or decrease the pulse width of the injector, changing the amount of fuel per cycle in low/med/high RPM ranges.
That is the first three settings of Green, Yellow and Red. Each half-step equals a 3% adjustment.
The next two settings (Green/Blue and Yellow/Blue) affect what RPM the midrange and high settings come into effect. Bringing the G/B down to 2 seems to have the biggest effect on smoothing out the low-rpm surge/bog that some have experienced.
The last setting, Red/Blue, adjusts the acceleration enrichment, which affects throttle response.
