Need help with swingarm bearings removal-2010 TE450
OlderHuskyRider
Never mind, I found that there is no lip inside the swingarm that separates the 2 bearings (on each side), this lip would require that the bearings come out they way they went in. I just started pounding on the outside bearing and it traveled all the way to the inside bearing and they both pushed out, should be done shortly.
