Need help with spark plug
Bl510tx
Got a 88 510tx and got a new spark plug but it won't start, is there a wire that connects to the spark plug to the plug boot?
There's got to be a better answer then that.
Correct, there is. But to be honest I'm not sure what the question is?
There is a high voltage spark plug wire from the coil to the spark plug boot which contains a round piece of metal that when pushed down on the spark plug makes the connection.
This has got to be a joke if not take your bike to someone who knows what they are doing. Not trying to be mean but somethings are better off left to the pros.
That's not who I am. Through problems come learning followed by solutions. I will upload a picture of questionable areas.
Could be you're not pushing the boot down until the wire grips onto the plug. I'm not sure if that bike needs to have the screw-on (terminal nut) on the top of the plug or not. If it needs the terminal nut and it's not on the plug you won't get a viable circuit. If it doesn't need the terminal nut and the terminal nut is installed theres no way the spark plug cap will push on fully- also not a viable circuit.
Take your spark plug and push it into the boot, then lay it on the side of the cylinder where it may touch ground. See if you have a spark as you kick the engine over.
