Need A New Battery!
Declan D
Hello, i need a new battery, my old one is fried and it wont hold a charge anymore. What batteries you guys recommend and use. And are there any that i can find for a quick replacement that a can find at a auto zone or something similar.
I have a: 2008 te 450
I use an energizer BS240. You have to mix it yourself and charge it before use but it will last the longest. other than that any other battery will work as long as you regularly ride and keep it charged.
a battery tender is your best friend. i have all my bikes on chargers. even a conventinal battery will last almost 6 years if you stay on top of it. that being said, i now go with the new lithium ion batteries.
Earth X is what I use and have had good luck with up to 4 years life in Ducati and 2 and a half currently on my 310. I do use a Battery Tender as shown as it has a lead acid and LI setting. An older BT jr. had some issues charging on the bike but this one has been great. No clicking and the Earth X only needs a few minutes to trickle and be at full charge. That said. Once they fail it's pretty sudden. My plan is normally replace in 2 years based upon last few batteries if heading on a trip where you just don't need a failure.
I have 4 years on my current Shori with no issues. My buddy use the WPS and has had about the same life. Neither of us have used a battery tender to date.
Paw Paw
Lithium is the go as it has generally higher amps -good for cold starts and are significantly lighter. They also need less tender time.
