Troy F Collins;18852 said:
Hey T I hear ya....nothing but bran muffins for me....good advise
1) where do the tether straps mount to eg from where to where.??
2)did you have any issues with using it with a chest protector...if not what kind do you wear....I have a thor quadrant
I fyou are wearing a Leatt, the tethers are the straps that come from the back brace portion.... beleive it or not, they velcro in and are sandwiched into the brace. They come areound to the front where there is a plastic double sided clip that they snap /press fit into.
The back brace/strut portion is fully adjustable to your body shape... I'm big chested 52" chest and have a 19" neck ( easy boys) 6ft 240.... and my body style is that of a power or weight lifter...I like to lift...... I tried about three different positions before going back to the very first one, which just happened to be the recommended one in the set up manual.... If your thin, or average build, like most everybody but me is, you may want to play with it... It seems to me the most injuries that i have seen are on thin guys....???? just what I have seen.
The back brace ramp that smacks up and limits your helmet/neck moving to the rear is also adjustable..... each helmet fits your head differently so you need to adjust it to the range of motion that you like, with your helmet...... this is where it is nice if a buddy is there to help you....
the Leatt also can be fitted with XL pins in the middle if you need more neck room.... I mention this as I have a 19" neck...... I thought I would for sure need the XL pin set and Leatt in Valencia Ca sent me a set overnight UPS for free just by asking
Turns out I haven't even used them.... the standard pin set feels just fine....
Adjust all of this at your house , when you have plenty of time to dick with it..... put your gear on, including chest protector and even if you feel like you look like a moron , ride up and down your street or driveway, the neighbors cow pasture or whatever you have at your house and adjust it several times until you find what you like.
DO NOT ATTEMPT TO ADJUST THIS ON THE DAY OF YOUR RIDE WITH YOUR BUDDIES.... IT WILL SCREW WITH YOUR RIDE TIME.....!
Chest protectors..... each one is unique.... I use a 661 under Armor and in the hot summer months here in California I also wear a 661 Core Cooler around my neck and shoulders... ( Cool cores are better than sliced bread) with all three on , everything still fits and wears just fine....
I'll be honest, it takes you a little longer than the guy that just grabs his helmet and rides off with a t-shirt..... but the safety is worth it... I have also used an external Thor "Force" chest protector,(which I absolutely hate) and it worked just fine....... some guys cut their chest protectors and mount them direct with/to the Leatt..... I think Blake does that.
Put your Leatt on first, tighten and set the tethers in place, put on your chest protector, then your Hydration pack and then your helmet
Hydration packs..... I wear my Leatt with both an OGIO hyd Pack on the track as well as carry about a 30Lb Camelback Hawg...when desert riding..... both fit fine over the Leatt and do not restrict range of motion......
Just my opinions again****************************************
T
