banana944
My 2009 SMR510 was running great, quite no ticks no noises with just 4k miles. I had an unfortunate stator failure that flatlinned the bike. Stator mount bolts backed out and took out the stator. I replaced the stator and flywheel with good used units. At the same time I installed the RR water pump. Pulled the cover and removed the nut holding the impeller. Was trying to work the impeller off the shaft when it pull the shaft with it and threw off my timing.
I posted a previous thread about my issue and timing the engine. It can be found here for some backround information. http://www.cafehusky.com/threads/need-help-timing-2009-smr-510.84165/
I got the engine timed and set (incorerectly marked cams from factory caused grief, see previous thread). Upon startup I had a pretty serious knocking noise. I am pulling my hair out trying to track down the source. It is really not apparent at starter cranking speed, but once it fires to life it is very audible. The rate of the knock increases linear with RPM. The engine seem to run, idle, and rev nicely besides this knock.
What I have tried:
1. I purchased a used Exhaust cam to make sure I wasn't having any issues with my incorrectly marked exhaust camshaft. I reinstalled and the knock still persists.
2. Bench tested the cam chain tensioner. Teeth look good, and ratchet mechanism holds when smacked against the work bench.
3. I pulled the head off and all timing components. The piston shows no sign of kissing a valve, and all the valves look good. This confirms my timing procedures were done correctly. I have not removed jug to check condition of rod.
Currently I have recieved my last bits from Hall's and I am looking to reinstall the head this weekend. The head will be reinstalled with all new timing components, guides and chain. What makes me very frustrated is that I still have not found any obvious sign of what is wrong. I am afraid I will get the bike reassembled and the knock will persist.
Can anyone else think of any suggestions before I reassemble the engine?
What I have tried:
