my '81 250cr
Bigbill
I removed the head and cylinder from my '81 250cr. I found a brand new piston in it so it was never started. I have to split the case now and replace the crank bearings and seals. Somethings fishy why it was never ran??? I got it last month from a cycle salvage shop.
Just a thought, although you've probably already removed the ignition cover... A long time ago we bought a Bultaco Pursang, it had a fresh rebore and new piston due to a seizure, but they said it wouldn't run. We found that the heavy Femsa flywheel had sheared the stub on the crankshaft when it seized. It broke right inside the main bearing, so the crank still turned and the flywheel was in place. The timing was another matter.
no spark?
Could be no spark the spark plug is brand new too.
Timing?
Ignition?
Crank seals?
Reeds?
I just find it odd to purchase a complete engine from a salvage place that's like new.
