motor swap
disonny
whats the chances that my 82 430 will fit in a 84 510 frame? The front mounting holes look very close to my 82 frame.
Believe the 2t exhaust port would hit the frame at the main down tube( the 2 have a bent tube).
A AC motor in a monoshock frame.
It seems to be a 510 frame. But not sure when you look
an inch above the exhaust port. The down tube seems thinner ( or is it a plastic wire ?)
or a thinner tube welded to the big tube ?
the direct answer is the case design is the same just adapted for a cam chain so mounting points work
if the exhaust angle of the port clears and you can make a pipe why not
but why would you unless you have a bug to do this, pretty sure a correct frame can be had
I picked up the 84 roller and it's pretty nice. I was going to take the 430 out of my 82 but now I think I'll find a motor for the 84. I figured no sense in breaking up the 82.
  • Like
Reactions: RUF
Good luck with finding a Husky 510 air cooled motor. Many were transplanted into specials builds. I think Andy has one for sale on HVA Factory website. It's an 86 aircooled.
