Missing kill switch
Caden
I have a 1983 husky cr250. But I don't have a kill switch. I have 3 bare wires and I don't know what they go to. I have a red a blue and a yellow. And I don't know if I need a 1 or 2 wire kill switch. I need help please.
Make sure you get a 2 wire kill switch to make sure the ground is unquestionable. These are no fun if you can not shut them off when you need to.
Take a few pics of your mystery wires and post them here. I'm sure we all can help you out and get you squared away correctly.
I in gonna do a two wire killswitch then I need to know how to connect it. I have a red yellow and blue wire coming from my sator without a connection
start it and hold the frame and grab each wire in turn. the one that stops the bike is the kill switch...:popcorn:
Well from the way the wire diagram looks. It looks like the kill switch comes from the ignition coil. And I only have two wires coming out of there. When I should have three. Two on one splice. One in the other.
250-wr-003-jpg.26451
The bottom one may help you sort things out.
yellow wire is to regulator and then to front light
green wire is to rear tail light
blue wire from ignition goes to large spade clip on the coil and that's where your kill switch wire ties into
small black from ignition goes to small spade clip on the coil alone
red wire I don't know maybe nothing. leave for now ( tape off tho)
green wire from kill switch goes to ground on the frame not the handle bars.
hope this helps.
So I get a 2 wire kill switch. Put the none green wire in with the spade connected in the coil. Then take the green wire and ground it on the bike frame? If that's right. Where should I ground it and how?
Run the ground wire down the frame under the gas tank & use one of the coil mounting bolts
You got it, that nut in the pic you posted that holds the coil to the frame . scrape some of the paint to bare metal then put the wire connector on then the nut will hold it down. Make sure the wire connector touches bare metal or you will likely have trouble down the road.
