Mikuni Conversion
Vinskord
A question for those that have done a Mikuni 36mm conversion to their pre 75 Huskys - have you had an interference with the vent coming off the right side of the carb with the aluminum air filter cover (pic attached)? Prior to cutting a notch in a perfectly good cover, I thought I see what others have experienced.
Well, since George has dealt with this issue about a thousand times in his day his suggestion is going to be your easiest and most common solution short of machining another part.
