might be getting divorved from my txc310 soon.
Husky Newbie
hello everybody, I have a 12' TXC 310 I purchased new in April,(now sept) Ive already replaced the starter/ring gear,Battery,temp sensor. I was out on the bike a few weeks back and was running perfectly for 45 min. I shut the bike off for 30 seconds,went to restart and it wouldn't fire. turned over as if battery was good. fired with just a small pop every 4 or 5 rotations. brought it home and started messing with it. fuel filter was dirty. went ahead and installed new cacycleworks fuel pump and new filter. all back together, replaced temp sensor again, nothing. I got fuel,fuel pressure,spark, good battery. wont fire with a shot of either thru the throttle body when turning over. havent replaced injector or TPS yep. but the either shot disproves the injector. Valves are in check,I don't have Ibeat and my local dealer went out of buisness. im on my own. thanks in advance, Bill
Is the off road park still open in Chattsworth? (sp?). I loved that place! Trails were great as well as the tracks. Also, wasn't a bad price.
Thank you R Little. ended up being a sheared keyway on the flywheel. Thanks to everybody on this board , Ive been lurking around since I bought this bike and the info found here has been very helpful.
and I'm from Pittsgrove and ride the pines as well as the millville area. thanks again Bill
I hope you get that bike sorted. I've had my 250 about 9 months now and have been thrilled with everything about it.
Same as me and others.
Get some Locite 609 and some valve lapping coupound and some Prussian Blue to check fit. Lap it a touch, put some 609 on the clean flywheel taper and tighten it to spec plus a smidge.
Is the flywheel taper scorred from the key? Did you get the old key out?
I have the stuff if you need to borrow it.
