mesh oil filter
nep2012
I recently changed my oil in my 2012 Te 310 and did not see the mesh oil filter. Is this a bad thing?Replaced the regular filter(K & N 116) but when I took off the drain plug underneath the engine there was no mesh filter.
It's probably their. You've gotta fish it out. I cut a piece of safety wire about 6" long and bend a hook on the end with a radius small enough to fit in the drain hole and gently try to snag the lip of the screen and pull it out.
Thanks I'll try that on next oil change. The whole drain plug mesh filter thing is bizarre. Couldn't they have come with a better design like just a simple drain plug.
