BR1
I read a lot of threads where people try to enrich/lean their air-fuel mixture by adding pcv, jd tuner, ecu maps... ecc
Last week I bought the Memjet Evo module. It's a kit that acting on the inlet air temperature sensor makes the ecu enrich/lean mixture.
It's totally safe beacuse you don't flash maps on your ecu or modify it. You only false the real air temperature by acting on a knob. It's the original ecu of your bike that manage maps in the colder/higher temperature measured.
It's also very easy to mount, and it's available for a lot of bikes and it's universal: the only things that change in the pack, are the inlet air temperature sensor connectors.
These are pics of the module (I will upload mine asap):
The results on my bike are that the engine runs better, the bike is more linear, it seems more powerful. No more pops/bangs
when decelerating. You're are riding the bike with the same map but richer.
Normally in Italy, this product is reccomended when you change the original muffler with a racing one, when the mixture becomes too lean.
For me works perfectly and it's also a lot cheaper than pcv. Obviously it's not the same, but for a normal use of the bike is fantastic.
when decelerating. You're are riding the bike with the same map but richer.Normally in Italy, this product is reccomended when you change the original muffler with a racing one, when the mixture becomes too lean.
