Mazoc's leaking fork fluid
ghte
Guys I believe the top of my twin chamber Mazoc 50 (right one) is leaking. Is this likely to be too much pressure building up and its self releasing via the bleeder or do I need to tighten the cap. penny for your thoughts.
All speculation on my part... but
Top cap leak seems unlikely but loosen the top tripple bolt on that side- then tighten the cap. Then tighten the tripple bolt.
I suppose if the bleeder was failing- it could be inhaling and exhausting every time you pump the forks through the bleeder and with it small amounts of oil. If you press that bleeder, and it is always at zero pressure maybe its the culprit. The bleeder has an o-ring seal that may have not been reinstalled upon maintenance- or the internal seal of the bleeder could be poor.
Thank you for the feed back I will try to tighten the cap, then pump her a few times to establish if the cap leaks and or there is any pressure build up internally. Thank you again.
Is it leaking from the bleeder or from around the red anodised bolt? I think if the oil has been in there a while fine particles can migrate. It can get caught in and get through the the seal or just wear it away, but it isn't that common.
