"mapping"
hpmainiac
OK, I just bought a 2012 TE 310. I haven't ridden enduros or at all really for 35 years but am going to get back into it.
I always had 2 strokes. Anyway, what is "mapping" a 4 stroke? As I understand it, it has to do with fuel feeding, etc. So what do I do to make my TE motor be in "full power" form?
I just picked the bike up 2 days ago and there is too much snow right now to ride so I have only ridden it about 150 yards. Your help and/or explanation is greatly appreciated.
If your TE310 is the US version, you will need to swap out the air filter cage, remove the lambda sensor from the exhaust, and install the power up resistor in its place in order to get full power out of the bike. If that does not get the results you want, there are several other options available. From what I have seen here, most folks seem to have the best results from installing the TXC ECU and injector.
