Maintenance procedure (repost)
robertaccio
Just a suggestion, every now and then pull your ignition cover and clean up your stator, flywheel and pickup assy. I have posted this in the past related to my TXC450. I just did my TE310 it had lots of magnetic particals and slivers all over the 3 parts. I cannot give a factual electronic fault or degrade of the system because of this dirtying of the parts. But Its never good to have particals stuck onto components. So clean your stuff up.
Did you put a new gasket on, or use teh old one? I have a small bit of oil weeping past the rubber gromet on the wire loom from the stator. I put some RTV on it from the outside and it slowed it down but did not cure it. Are you getting some oil weeping?
Did you put a new gasket on, or use teh old one? I have a small bit of oil weeping past the rubber grommet on the wire loom from the stator. I put some RTV on it from the outside and it slowed it down but did not cure it. Are you getting some oil weeping?
I Installed a new gasket and always use a thin coat threebond 1211 (IMHO the best RTV seal stuff out there) around all those rubber grommet type seals.
Oil was weeping form the grommet area when I first bought the bike but the same procedure cured that issue. (It's a 15 minute job to do the entire process, ok 1/2 hour if you take your time)
