Loud Exhaust
ozzie
Riding home on my last ride I notice that the note from my pipe had become louder, so before I pull it apart I thought that I would ask the question, has any one done this before and what are tips to do this before I start? Is it like a 2 stroker muffler that you have to repack??? My ride a TE 450 with a Arrow muffler
Cheers Kel
My 08 Arrow exhaust is nothing like that 09 shown in the links above. On the 08 I drilled 4 or 5 pop rivets on the forward side of the muffler, and pull the outer alunimim can off. the inner core is stuck to the front 1/2 of the exhaust. Then I tapped the holes (forgot what pitch) and inserted 4 (or 5) flat head Allen screws with Red lock tight. NO inside wrapper as shown above, no welding to remove.
Right- the 08 is different- the Stock 08 exhaust had a cat that you replaced entirely with the 08' PU Exhaust which was not made to work with a CAT- so you would not have the stainless inner shielding like with the 09-10s. A 08Arrow PU Exhaust is just like repacking most exhausts. :thumbsup:
So the cat is inside the can of my stock 08? I thought it was in the header pipe ahead of the muffler joint. Mine is used so I assumed the last owner popped it out.
I do know my Arrow with spark arrestor is the same noise level as the stock muffler without the spark arrestor. I never knew the spark arrestor switched into both mufflers until I pulled the arrow to check the packing (I put stock muffler back on while I was waiting to go buy bolts to put arrow back together). Stock muffler with spark arrestor sounds great to me. But it is a good amount heaver.
My buddy is cutting me a piece that will fit into exhaust like spark arrestor, but has 3/4" ID hole with set screw do I can try to build my own baffle to bring the noise down on the Arrow.
So the cat is inside the can of my stock 08? I thought it was in the header pipe ahead of the muffler joint..
Right. THe stock 08' TE pipe, not the PowerUP pipe, has the cat. In 2009-2010, the cats were moved from the can to the mid pipe near the joint on the can side. SO on 09-10s the "powerup" pipe was actually on the bike- you just had to remove the cat- which is easily slid out after separating the mid pipe and from the slipon/can.
That's (because if you run the cat it gets HOT) why the 09-10 have the inner stainless shell that I removed when repacking, and also why the stainless shell is not part of the 08' PU can.
