lost rear breaks on a 10' te450
te450dean
Hey had a big stack on the weekend riding some rough single track , any way reason why was iv came down a hard left with some pace and hit the rears to slide in and there was no feel at all and ended up way off track. Had a look st all mechanical parts and all was working ok just had no pressure in the leaver at all and noticed the banjo at the caliper had a little fluid around it.
So assuming I lost all the fluid some how just wondering if anyone else has had this issue don't want to just put more fluid in and it happens again. It's a 2010 te450 with standard brembos
Thanks for any advice
Just sounds like it's come lose and now you have air in the system, needs bleeding, checking over for leaks or fractures and off you go again?
I lost pressure on mine one day in some tough single track but it was due to me drag braking, overheated the fluid, the brake cam back after cooling, I didn't do anymore drag braking.
Check the brake line near where the master cylinder sits - Follow the line, check that the line hasnt rubbed away where it contacts the crank case (it heads towards the motor then loops back and sits along the swingarm, that loop contacts the motor). I noticed mine is worn through to the steel brading, if it keeps rubbing it will wear through that and I will lose rear braking.
I hate that "Stupid Loop"...
Here is the wear on my stupid loop.
The external piston that sits in the rubber sleeve from the brake pedal
Here is the fix... It wont last long. I will replace it with race tape or maybe some nylon sheet wrapped around the tube
