need2boat
2012 HUSQVARNA TXC 310
The previous owner wired up a switch to the fuel pump that he mounted behind the plate. It was a click lock button style. He then broke the ground to the starter with a kill interrupt switch. To stat the bike you pushed the button the fuel pump starts and you press the interrupt switch.
The issue is the button switch he used is to light weight and it's fried. Can anyone tell me on the 2013 TXC I notched they have two switch a kill and run. Can anyone tell me is the run/power switch a lock style. If so I can look into getting one to use as a replacement.
thanks
Joe
thanks
Joe
