Linkage Bearings - fyi
Wolf
I decided to redo the linkage bearings on my 09 txc 250. I had one heck of a time getting the old ones out. So I went to a friends shop to use his press. It took all of the 20 tons to get them out...upon inspection it turns out there was a shoulder in the center, we ended up pressing right through it. I would have never ever guessed that, and have never seen that before. How the heck are you supposed to press a bearing out with a shoulder in the center? Or maybe this was a bad casting? We got it all done, and there is now no longer a shoulder in the center between the bearings :)
Hello Wolf your suppost to use a bearing puller fot these type of bearings it's not uncommon this construction
I also was not aware of the inner shoulder, but I caught on to it before too long, ended up pressing/destroying the old bearings from the opposite sides/outward and buggered the inner shoulder pretty badly, but it's still there and works to keep the 2 bearings apart from each other.
Lol...Yup, you are all correct. This was a non issue on my KTMs - no linkage - and the YZs didn't have a shoulder...should have read the manual :)
I took the needle bearings out and then angled a smaller diameter deep well socket against the bearing lip from the opposite side after heating and struck it gently with a hammer.Took about 10 min.
What Blake said, I just did mine yesterday, I use the part from the blind bearing puller set I have and press from the opposite side. I just did a few on my 125 yesterday and it took less than 30 minutes start to finish.
Later,
