Lighting capability 2009 TXC450
webski
My 2009 TXC450 has this unused plug in the wiring harness under the tank. Is this a plug and play for lighting? The wires going into it are red, blue and yellow.001.JPG
Yes. It comes straight off the alternator, so it is AC. I found this out when I was connecting turn signals and the flasher wouldn't work. I installed a fused connection to the battery to run the signals and horn.
Does this provide enough power for a Trail Tech HID system?
I think its technically for a fan, but we used it to wire up Trail Tech H2 (non-HID) headlight, LED taillight, horn and LED turn signals. I don't know if the TXC stator can support HID or not.
Same as on the 250. One is the ground, one is permanently hot, coming off the battery, one is off the alternator.
Reopening an old thread here.
I've got a TXC250 09 model, I'm planning on running just a headlight the globe will be 35w.
Can I run it straight of the Yellow Stator wire or just I use the yellow wire as a trigger for a relay and run the main cables off the battery?
Thanks
Neil
