kyb single chamber
josh310
My forks started leaking on my 2011 te310. I am in the middle of putting seals in them and i downloaded the shop manual off of the internet. The shop manual say to just fill the oil to the top edge of outer tube. Is this right? I see all over the internet were they want the oil a specific level below the outer tube. Also I way around 160lbs and the forks feel good to me stock but could they be better? Should i do other work to them while i have them apart? I was going to put 5w back in them.
I just did mine last weekend and with the help of others that posted to my questions, I went 120 mm down from the top of the tube. I also posted a link to a video showing how to do it.
Doug
I run mine at 120mm with forks compressed and no springs in, 5wt oil, work great. You can always add more oil if they bottom out.
