just picked up an 09 te 450. Need another master link for the chain
Jake1z
The binge had a two.tooth bigger sprocket in the rear and the tire is too close to the swing arm.. the chain is a brand new replacement chain according to the previous owner.. I need to lengthen it so I can move the wheel back further. I read that I can't use any old master link so where can I get.one? Thanks
Cycle shop will SOMETIMES sell you a master link, they will tell you that it needs to match the chain since all 520 chains are different widths....whatever.
Do you have an extra master link? If you do, I'd use it.
When I replace my chain, I always order an extra master link that goes with the chain I am buying and I put that link in my tool bag.
It's not just the width of the chain, the pins can be a different diameter too. I have a bunch of master links for 520 chain and none of them fit the stock chain on my 2010 TE
Ya that's what read. The pins are the problem.. I guess I'll just wait for the chain to stretch... it's not hitting the mud flap but it's pretty close to it. From what I read on the other threads in the forum its ok to be pretty close and that it helps with tight turning..
If the tyre is close to the mud guard then it might also grab/rub the exhaust pipe when you use the rear suspension travel. Mine did, but that was with a big fat Dunlop 606.
